PMC軟體 40A7 edition 03 (31i-B series step2)
版主: TCReporterTCReporter
蔥抓餅
文章: 94
註冊時間: 2017-04-07, 09:46
文章 蔥抓餅 »
30i/31i/32i/35i-B PMC 在40A7 V02版 產生ER61 對策
Problem
PMC alarm ER61 raises and I/O Link i fails to link.
Condition of the failure to occur
The failure occurs when all of the following conditions.
- Series 40A7 edition 02 is used
- I/O Link i is used
- I/O device with MPG is connected
- Drawing number of the main board is as follows:
- A02B-032x-H100
- A02B-032x-H102
- A02B-032x-H200
- A02B-033x-H100
- A02B-033x-H102
- A02B-033x-H200
Cause of the failure
The modification for the new I/O Link i hardware affected the assignment process of MPG slot and caused
the error.
Countermeasures
Please do one of followings.
- Update PMC system software series 40A7 to edition 03 or later.
- Turn on the keep relay K999.1 that disables the modification and restart CNC.
(* Use this countermeasure to avoid the problem if the software update is difficult)
40A7030.zip
(1.18 MiB) 已下載 5 次
19091E_A-42151-018EN@01.pdf
(48.89 KiB) 已下載 6 次
19091J_A-42151-018JA@01.pdf
(162.43 KiB) 尚未被下載
回到「31i-B 系列」
