FsBP 技術報告
TCReporter
文章: 2021
註冊時間: 2018-12-05, 09:43
Re: FsBP 技術報告
文章 TCReporter »
FsBP V3.1.0 版更新
24019E_A-45261-00060EN_01.pdf
(140.03 KiB) 已下載 5 次
24019E_A-45261-00062EN_01.pdf
(868.21 KiB) 已下載 3 次
FIELD system OS 4.2.29
Base Software 4.0.1
FANUC CNC Converter 3.8.7
FANUC Robot Converter 3.0.2
MTConnect Converter 3.0.0
OPC UA Converter 3.0.0
Converter Common Setting Tool 3.2.0
OPC UA Server 1.3.0
Common Data Import/Export 3.0.7
Factory Visualizer 2.1.0
Event Database 2.3.2
Common Data Viewer 1.3.5
Utility Toolbox 1.5.0
Machine Maintenance (New additon) 1.0.0
FANUC Servo Data Connector (New additon) 1.0.0
FANUC CNC Program Transfer (New additon) 1.1.0
Extension API (New additon) 2.0.0
No.1 Security update
Updated the software and libraries that make up the OS and applications.
The target software are as follows.
- FIELD system OS
- Base Software
- FANUC CNC Converter
- FANUC Robot Converter
- MTConnect Converter
- OPC UA Converter
- Converter Common Setting Tool
- OPC UA Server
- Common Data Import/Export
- Factory Visualizer
- Event Database
- Common Data Viewer
- Utility Toolbox
No.2 Improvements of FIELD system OS
(1) Simplified data retrieval settings for CNC and ROBOT.
(2) Added ability to configure ‘Equipment’ functionality.
(3) Added abiity to configure equipment 'Groups'.
(4) Added ability to set equipment access with 'Roles'.
(5) Simplified the FsBP BOX restoration process.
(6) Added ability to set the FsBP BOX system time via the BOX Settings Tool Web app.
(7) Added ability to retrieve past resource log information via the BOX Settings Tool Web app.
No.3 Improvements of FANUC CNC Converter
(1) Added "9" for DCSPMC to PMC path number selection.
No.4 Improvements of MTConnect Converter
(1) Following Extension APIs have been added.
probe: Issue Probe request to MTConnect agent
current: Issue Current request to MTConnect agent
sample: Issue Sample request to MTConnect agent
asset: Issue Asset request to MTConnect agent
(2) Following Extension APIs (old name "RPC methods") have been deleted.
field.get_variable: Read DataItem, or acquire device information
(3) In Collect setting with CSV, Nodes whose NodeId is not defined in the available data has been able to be configured.
(4) Default value of "Default script type for Calculation" has been changed to Lua.
(5) Behavior of Calculation with Lua script has been changed if one or more variables are failed to get.
No.5 Improvements of OPC UA Converter
(1) Device configration auto config has been available with the following OPC UA servers.
UA4MT(umati) servers
EUROMAP 77/83 servers (includes ROBOSHOT-LINKi2)
(2) Following Extension APIs have been added.
browse_node: Execute Browse service for Node
execute_method: Execute Call service of Method history_read_raw: Execute HistoryRead service for Variable
read_variable: Execute Read service for Value attribute of Variable
write_variable: Execute Write service for Value attribute of Variable
(3) Following Extension APIs (old name "RPC methods") have been deleted.
field.get_variable: Read Variable, or acquire address space information
field.set_variable: Write Variable
(4) Progress of updating available data (acquiring address space) has been displayed.
(5) In Collect setting with CSV, Nodes whose NodeId is not defined in the available data has been able to be configured.
(6) Default value of "Default script type for Calculation" has been changed to Lua.
(7) Behavior of Calculation with Lua script has been changed if one or more variables are failed to get.
No.6 Improvements of Converter Common Setting Tool
(1) New functions of each converter have been supported.
(2) Setting validity period of Device configuration auto config has been extended to 300 minutes.
No.7 Improvements of OPC UA Server
(1) Methods for executing following Extension APIs have been added.
・OPC UA Converter
・MTConnect Converter
・FANUC CNC Converter
get_macro_variable: Get custom macro variables
set_macro_variable: Set custom macro variables
(2) User authentication by FsBP username/password from OPC UA client has been added.
(3) A configuration for accepting untrusted OPC UA clients' certificates has been added.
No.8 Improvements of Factory Visualizer
(1) Added operation monitoring group function.
(2) Improved data source settings screen.
(3) Improved data management screen display.
(4) Added automatic template update function.
No.9 Improvements of Common Data Import/Export
(1) The screen design and function names have been changed.
No.10 Improvements of Common Data Viewer
(1) The waveform data function has been removed.
No.11 Improvements of Utility Toolbox
(1) Added event DB regular deletion function.
No.12 Addition of Machine Maintenance
New additions
No.13 Addition of the FANUC Servo Data Connector
New additions
No.14 Addition of the FANUC CNC Program Transfer
(1) Support for user permissions.
No.15 Addition of Extension API
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP
資料利用流程:刀具壽命管理
Data utilization procedure: Tool life monitoring
24020E_A-45261-00040EN_01.pdf
(1.87 MiB) 已下載 6 次
24020J_A-45261-00040JA_01.pdf
(1.92 MiB) 尚未被下載
24020E_A-45261-00041EN_01.zip
(12.46 KiB) 尚未被下載
文章: 2378
Re: FsBP 技術報告
FsBP V3.1.1版更新
No.1 Fixed of the FIELD system OS
(1) Fixed a bug on the BOX Operator overview screen.
(2) Fixed a bug in BOX sync.
No.2 Fixed of Factory Visualizer
(1) Fixed the log output method.
No.3 Fixed minor bugs
Fixed minor bugs in the following apps:
Event Database
Utility Toolbox
24023E_A-45261-00066EN_01.pdf
(67.32 KiB) 已下載 1 次
文章: 2378
Re: FsBP 技術報告
FsBP
資料利用與可視化流程:總消費電力 V2.0
Data utilization procedure: Total power consumption
24024E_A-45261-00033EN_02.zip
(15.59 KiB) 已下載 2 次
24024E_A-45261-00032EN_02.pdf
(2.28 MiB) 已下載 3 次
24024E_A-45261-00031EN_02.pdf
(296.82 KiB) 已下載 2 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP OPC UA Server 手冊修正
The modification of FIELD system OPC UA Server OPERATOR'S MANUAL
FIELD system OPC UA サーバ 取扱説明書の修正
25001E_B-30054EN-4_03-001_01.pdf
(227.33 KiB) 已下載 4 次
25001J_B-30054JA-4_03-001_01.pdf
(268.26 KiB) 已下載 2 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
修正FsBP 工廠可視化 新增陣列式物件加入參照方式
Modification of FIELD system Factory Visualizer Operator’s Manual_Added a method to reference elements of object type arrays
FIELD system Factory Visualizer 取扱説明書改訂_オブジェクト型配列の要素を参照する方法を追加
25003E_B-30054EN-7_03-001_01.pdf
(1.39 MiB) 已下載 3 次
25003J_B-30054JA-7_03-001_01.pdf
(1.4 MiB) 已下載 1 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP V3.1.10 版更新
25004E_A-45261-00074EN_01.pdf
(622.16 KiB) 已下載 5 次
25004J_A-45261-00074JA_01.pdf
(866.28 KiB) 已下載 1 次
1. 安全性更新
2. 支援韓語
3. 改善FsBP OS
4. 改善Robot 資料變數從50至100
5. 改善轉換器一般設定工具
5.1支援 Modbus TCP
5.2 顯示更多細節錯誤再Lua腳本
5.3 OPC UA / MTConnect支援節點至2000個
6. 改善OPC UA Server功能,支援Modbus TCP API讀寫功能
7. 改善工廠可視化功能,支援機械狀態紀錄器與可下載CSV檔案
8. 新增可批次下載伺服波形資料
9. 改善擴展API功能,支援Modbus TCP讀寫功能與連結錯誤時回傳碼
10. 新增Modbus TCP轉換器
11. 新增 機械狀態紀錄器連結器
- FIELD system OS
- Base Software
- OPC UA Converter
- OPC UA Server
- Event Database
- Utility Toolbox
- Machine Maintenance
- FANUC Servo Data Connector
- FANUC CNC Program Transfer
- Extension API
No.2 Korean language support
Korean language has been supported.
- FIELD system OS
- OPC UA Server
- Event Database
- Utility Toolbox
No.3 Improvements of the FIELD system OS
(1) Added factory reset function.
(2) Added MT-LINKi settings import (CNC/Robot) functionality.
(3) Added ability to add 'Standard Data' settings on the 'Data Collection Settings' screen.
(4) Added ability to set 'Diagnosis data', 'P-CODE Macro Variable' and 'String Register' on the 'Data Collection
Settings' screen.
(5) Added ability to set 'Default permissions' which are applied to all roles.
(6) Removed read permission from role screens since it is available by default for roles.
(7) Separated 'Equipment' and 'Equipment Groups' on the role registration/view screens.
(8) Added resultant permission on role registration/view screens.
(9) Added license information on the top screen.
(10) Added ability to give a name to a backup on the backup/restore screens.
(11) Changed URIs of BOX Operator pages. Update Bookmarks if required.
(12) Expanded maximum number of instances of Common Database.
(13) Added ability to confirm number of running converters.
No.4 Improvements of the FANUC Robot Converter
(1) Increased the max number of status_robot_controller_variable that can be set from 50 to 100.
(If too many status_robot_controller_variable are set, not all data may be collected.)
No.5 Improvements of Converter Common Setting Tool
(1) Settings for Modbus TCP Converter has been supported.
(2) More detailed information has been displayed as a validation error message of Lua script.
(3) Maximum number of auto collect target nodes for OPC UA/MTConnect Converter has been increased to 2000.
No.6 Improvements of OPC UA Server
(1) Extension API methods of Modbus TCP Converter (read/write) have been supported.
(2) Each element of an object type attribute (child attribute) in Common Database has also been defined as an independent Variable node.
No.7 Improvements of Factory Visualizer
(1) Support for integration with Machine State Logging functionality.
(2) Added a feature to download the data displayed on the screen as a CSV file.
No.8 Improvements of the FANUC Servo Data Connector
(1) Addition of batch download function of servo waveform data.
No.9 Improvements of Extension API
(2) Extension API methods of OPC UA, MTConnect, and Modbus TCP Converter have been modified to return an error immediately in case of a connection error.
No.10 Addition of Modbus TCP Converter New additions
No.11 Addition of Machine State Logging (Visual Assistance) ConnectorNew additions
簡介資料
25004E_A-45261-00069EN_01.pdf
(272.06 KiB) 已下載 3 次
25004J_A-45261-00069JA_01.pdf
(361.04 KiB) 已下載 1 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP
機械狀態紀錄器(視覺輔助) 連結操作手冊
Machine State Logging (Visual Assistance) Connector Operator’s Manual
機械状態監視機能(ビジュアルアシスト)連携操作説明書
25007E_A-45261-00075EN_01.pdf
(4.4 MiB) 已下載 4 次
25007J_A-45261-00075JA_01.pdf
(4.49 MiB) 已下載 2 次
JSON 檔案
25007E_A-45261-00079EN_01.zip
(6.37 KiB) 已下載 4 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP V3.1.10 版 網頁操作/設定更新 手冊
BOX Operator / BOX Settings Tool (Web) Updates
25008E_A-45261-00076EN_01.pdf
(2.92 MiB) 已下載 9 次
25008J_A-45261-00076JA_01.pdf
(2.94 MiB) 已下載 1 次
1. 韓文設定
2. MT-LINKi 設定檔匯入
3. 資料收集設定畫面更新(診斷/P-CODE變數/一般變數/字串紀錄器)
4. 使用者權限變更
5. 概要畫面變更
6. 重置原廠設定
7. 支援第二代FIELD Base Pro
8. VM版本FsBP(設定方式)
9. 備份標籤
1 Korean Display Language Support
2 MT-LINKi Settings Import
3 Data Collection Settings Screen Updates
4 Changes relating to Roles
5 Overview Screen Changes
6 Addition of Factory Reset Function
7 Support for FIELD Base Pro (2nd Generation)
8 VM Version of FIELD system Basic Package
9 Labels for Backups
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP Base Pro(第二代) 設備回收與利用率資料
Information for treatment facilities and recycling/recovery rate of FANUC FIELD BASE Pro (A10B-0004-B011)
25010E_A-65655-00002EN_01.pdf
(742.21 KiB) 已下載 2 次
回到「技術報告」
