FsBP 技術報告
TCReporter
文章: 2021
註冊時間: 2018-12-05, 09:43
FsBP 技術報告
文章 TCReporter »
FsBP V3.0.0 版更新
24001E_A-45261-00018EN_01.pdf
(95.36 KiB) 已下載 3 次
24001E_A-45261-00048EN_01.pdf
(1.15 MiB) 已下載 3 次
FIELD system OS 4.0.18
Base Software 4.0.0
FANUC CNC Converter 3.7.7
FANUC Robot Converter 3.0.0
MTConnect Converter 2.8.0
OPC UA Converter 2.8.0
Converter Common Setting Tool 3.0.0
OPC UA Server 1.2.5
Common Data Import/Export (Name changed from Data Tool) 3.0.1
Factory Visualizer 2.0.0
Event Database 2.2.0
Common Data Viewer 1.3.2
Utility Toolbox (Name changed from Notifier) 1.4.0
No.1 Security update
Updated the software and libraries that make up the OS and applications.
The target software are as follows.
- FIELD system OS
- Base Software
- FANUC CNC Converter
- FANUC Robot Converter
- MTConnect Converter
- OPC UA Converter
- Converter Common Setting Tool
- OPC UA Server
- Common Data Import/Export
- Factory Visualizer
- Event Database
- Common Data Viewer
- Utility Toolbox
No.2 Application name changed
(1) Application name changed from Data Tool to Common Data Import/Export.
(2) Application name changed from Notifier to Utility Toolbox.
No.3 Improvements of FANUC CNC Converter
(1) status_cnc_tool_offset class has been added.
(2) act_d_code, block_skip_signals, optional_stop_signal, single_block_signal attributes has been added to status_cnc_path class.
No.4 Improvements of MTConnect Converter
(3) In addition to the conventional script, Lua script can be used in an expression of "Calculation assignment".
No.5 Improvements of OPC UA Converter
(3) HistoryRead result can be assigned to an attribute with "Simple assignment".
(4) In addition to the conventional script, Lua script can be used in an expression of "Calculation assignment".
(5) Behavior at Timeout error of updating available data has been improved.
(6) Extention API history_read_raw that reads history data has been added.
No.6 Improvements of Converter Common Setting Tool
(1) Search summary page has been removed. Device Status page on BOX Operator has equivalent functions.
(2) Added or fixed functions for FANUC CNC Converter, FANUC Robot Converter, OPC UA Converter, and MTConnect Converter have been able to be configured.
(3) Generated classes with auto collect settings of OPC UA Converter or MTConnect Converter has been able to have multiple instances.
No.7 Improvements of OPC UA Server
(1) When the server settings are changed, it has been able to be selected whether or not to restart the server immediately to apply changes.
(2) OPC UA server has been able to handle Boolean type items. They are defined as Variable nodes of Boolean DataType.
No.8 Improvements of Factory Visualizer
(1) Added a function to view the operating status of machines connected to other FIELD BOX on the Overall Monitoring screen.
(2) Added data viewer function to easily view and analyze data.
(3) The UI of board settings has been changed to make settings easier.
No.9 Improvements of Event Database
(1) Added support for Master Dataset.
(2) Added function that test data collection settings.
(3) Added function that execute on specified period.
(4) Added function that naming to selected columns (same as SQL AS clause).
(5) Added support for Boolean type columns.
No.10 Improvements of Utility Toolbox
(1) Added function to output Common Data as a CSV file to a shared folder on the network.
(2) Added function to output Event Data as a CSV file to a shared folder on the network.
No.11 Improvements of FIELD system OS
(1) Default certificate has been updated.
(2) Improvement of the FIELD system BOX Operator.
(3) Improvement of the BOX Setting Tool web version.
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FIELD system Notifier 軟體名稱變更 FIELD system Utility Toolbox 與功能介紹
The application name has been changed from FIELD system Notifier to FIELD system Utility Toolbox
24002E_B-30054EN-5_02-001_01.pdf
(2.77 MiB) 已下載 2 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP
合併管理與操作手冊與BOX設定工具手冊
・BOX Operator (Explained in Section 2)
・BOX Settings Tool (Explained in Section 3)
24004E_B-30304EN-3_01-001_01.pdf
(2.24 MiB) 已下載 2 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP
修正工廠可視化操作手冊
Modification of FIELD system Factory Visualizer Operator’s Manual
24005E_B-30054EN-7_01-001_01.pdf
(3.97 MiB) 已下載 5 次
24006E_B-30054EN-7_01-001_02.pdf
(3.27 MiB) 已下載 3 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP 與 MT-LINKi 開發計畫時程表
24010E_A-45260-00056EN_01.pdf
(535.36 KiB) 已下載 2 次
24010E_A-45260-00055EN_01.pdf
(395.16 KiB) 已下載 2 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP V3.0.10 軟體更新
24011E_A-45261-00049EN_01.pdf
(209.5 KiB) 已下載 2 次
FIELD system OS 4.0.27
Base Software 4.0.1
FANUC CNC Converter 3.7.8
FANUC Robot Converter 3.0.1
MTConnect Converter 2.9.0
OPC UA Converter 2.9.0
Converter Common Setting Tool 3.1.0
OPC UA Server 1.2.6
Common Data Import/Export 3.0.2
Factory Visualizer 2.0.1
Event Database 2.2.5
Common Data Viewer 1.3.3
Utility Toolbox 1.4.2
- FIELD system OS
- Base Software
- OPC UA Converter
- OPC UA Server
- Event Database
- Utility Toolbox
No.2 Improvements of FANUC CNC Converter
(1) Support for multi-path PMC has been improved.
No.3 Improvements of MTConnect Converter
(1) HTTPS connection to MTConnect agents has been supported.
(2) More MTConnect devices have been supported by Device configuration auto config.
(3) New attribute (unit_position, unit_pressure, and unit_temperature) of quality_maintenance_injection class have been supported.
No.4 Improvements of OPC UA Converter
(1) Event subscriptions have been supported.
(2) DataType EUInformation and Range have been supported.
No.5 Improvements of Converter Common Setting Tool
(1) New functions of each converter have been supported.
(2) Changed so that only users with Administrator or App administrator rights can reflect settings.
(3) The import/export function for each configuration file has been deleted. (The batch import/export function remains unchanged).
(4) The display of ‘instance_def.json’ has been removed from the detailed settings page.
No.6 Improvements of OPC UA Server
(1) OPC UA Server has been launched with a minimum configuration if configuration files do not exist.
(2) Endpoint URI has been displayed on the top of Basic Settings.
No.7 Improvements of Factory Visualizer
(1) Added support for displaying array data of Common Data.
No.8 Improvements of FIELD system OS
(1) Improvement of functions for integrators.
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP
資安對策
Security Measures
24013E_A-45261-00053EN_01.pdf
(1.68 MiB) 已下載 2 次
24013E_A-45261-00055EN_01.pdf
(163.07 KiB) 已下載 2 次
#安全性對策
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP
資料利用流程:ROBODRILL 維護資料監視
Data utilization procedure: ROBODRILL maintenance data monitoring
24014E_A-45261-00034EN_01.pdf
(1.38 MiB) 已下載 5 次
24014E_A-45261-00035EN_01.zip
(12.53 KiB) 已下載 5 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP
工廠可視化:過濾器設定流程
Factory Visualizer: Filter setting procedure
24015E_A-45261-00036EN_01.pdf
(1.3 MiB) 已下載 3 次
TCReporter
文章: 2021
Re: FsBP 技術報告
文章 TCReporter »
FsBP
設備處理回收利用率資訊
Information for treatment facilities and recycling/recovery rate of FANUC FIELD BASE Pro
24016E_A-65655-00001EN_01.pdf
(301.73 KiB) 已下載 2 次
回到「技術報告」
